Re: Brakes on a regular
Posted by James Williams on April 15, 2007 at 17:55:31 from (65.73.13.20):
In Reply to: Brakes on a regular posted by Dan in Ore on April 15, 2007 at 16:56:31:
Dan,One brake lever,I'm sure you have a multi disc clutch and if all is right that is all of the brake you need with steel wheels.I think the hand brake is for holding a load and parking.I was plowing with mine and hit a rock break,front of tractor slid into the fur and I didnt know if I would ever get it straighten out.Tractors have come a long ways
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
