Re: The B is finally unstuck!
Posted by Greg Hansen on April 16, 2007 at 05:55:32 from (71.33.113.65):
In Reply to: The B is finally unstuck! posted by bshannon on April 15, 2007 at 16:33:43:
If the pistons aren't froze too bad, what sometimes works is after putting penetrating oil in the cylinders for a couple of days is to put the tractor in high gear and gently rock it pushing on the drivers will sometimes free the cylinders up.
