Re: HEAD ON FARMALL 140 HELP ;;;;;;;;;;;;;;;;;
Posted by NawlensGator on April 17, 2007 at 08:56:07 from (52.128.30.25):
In Reply to: HEAD ON FARMALL 140 HELP ;;;;;;;;;;;;;;;;; posted by COPPER KAT on April 16, 2007 at 18:17:14:
The standard compression is a little less than 7 to 1 so there is room to shave the heads and gain some compression.
Adding a 40,000 volt coil (~$40) lets you open the gap from 0.025 to over 0.040 which increases power a little.
Other things not involving the heads include higher compressiion pistons, increasing the rpm's (govener), or increasing sleeve bore.
