Well...
Posted by A. Bohemian on April 17, 2007 at 10:48:44 from (207.170.88.127):
In Reply to: Re: Ah, Itasca! posted by whompuscat on April 17, 2007 at 08:54:46:
...I'll tell you. But if the governor isn't working right, you will be wasting time. Worse; if the clevis is properly adjusted on the throttle rod, and you mess with the adjustments NOW, you will screw them up and have to reset them when the governor is restored to correct operation. (Fortunately this doesn't take too long.) Don't take my word for it; the IT manual contains the following warning, printed in italics FOR EMPHASIS! "Before attempting any governor adjustments, check the linkage for binding condition or lost motion and correct any undesirable conditions." Lack of resistance is the most undesirable governor condition of all! The governer works by conservation of momentum. No resistance, no conservation! So, once more, PLEASE grab the throttle rod coming from the carburetor with the engine off and work it through its range. You should feel very, very little resistance. Now, start the engine. Grab the throttle rod again and try to rev the engine. You should feel greatly increased resistance. If this resistance is not present attempting to adjust the governor is a waste of time. I cannot emphasize this enough. AFTER you have determined the governor is operating properly, shut the engine down. Move the speed control lever all the way to the high end of it's range. Remove the pin from the clevis. Now, hold the throttle rod and the rockshaft arm (the other piece of the assembly the pin hold the clevis onto) as far forward as they go. The pins should slide easily home. If not, turn the clevis on the threaded part of the rod until they do. (If I ever bet, which I don't I would bet fifty dollars that they will. Because I think the governor IS properly adjusted.) Now, to set the high speed idle: simply adjust the hex screw coming out of the top of the housing. That's all there is to it. But please, please, PLEASE, if you haven't done it, check the governor for proper resistance to motion before you do.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
