Re: 340 gas --Wet sleeve or dry?
Posted by El Toro on April 17, 2007 at 14:17:50 from (64.12.117.8):
In Reply to: 340 gas --Wet sleeve or dry? posted by ScottyHOMEy on April 17, 2007 at 13:25:51:
They are wet sleeves. You should consider putting a sleeve kit in it. Have the crankshaft measured for wear too. Close tolerances on the bearings determine's good oil pressure. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
