Super C govenor
Posted by whompuscat on April 18, 2007 at 07:35:24 from (216.93.135.201):
The problem that I have is that the govenor does not open under a load. I belive my govenor is in very good condition, However after a discussion, I tried to set my high speed linkage last night, I put the throttle lever at full throttle and disconnected the throttle clevis pin from the govenor arm. Whith the carb at full open the rod was too long. I screwed the clivis in to match the govenor arm but it will not screw far enough to match the pin holes. But it did work better.
Should I adjust the govenor's arm?
Got any ideas?
