Re: 450 Torque Amplifier
Posted by the tractor vet on April 18, 2007 at 08:21:48 from (76.212.225.46):
In Reply to: 450 Torque Amplifier posted by georgeky on April 18, 2007 at 07:08:48:
Pull the cover off over the T/A clutch and look in and see what is happening. Could be that someone before ya put a stright shaft in or weled thing together rather then fixen . May be a stuck T/A clutch Don't know i ain't there to look and check things out.
