Re: 450 Torque Amplifier
Posted by georgeky on April 18, 2007 at 08:57:35 from (152.163.100.197):
In Reply to: Re: 450 Torque Amplifier posted by the tractor vet on April 18, 2007 at 08:21:48:
I haven't looked in there yet, but I was thinking maybe the clutch could be stuck. I thought maybe something wasn't right because someone took the handle off and never put it back. It also seemed like the linkage I put on it was a little short. I had to run it out to the very end to get it to fit the lever were it was soppose to be. It came off a 400. Someone said that the handle has a different part number than one for the 450. Is that right.
