Re: H psi
Posted by chadd on April 19, 2007 at 14:11:47 from (155.92.32.116):
In Reply to: H psi posted by Pat-CT on April 19, 2007 at 13:53:16:
First off, you can put the same grade of oil in the air cleaner that you put in the crankcase.
Second off, I know an M should have between 45 to 70 psi of oil pressure. Your H has slightly lower oil pressure I believe, so I would guess somewhere around 35 to 60 or so. I am sure someone who owns an H can give you more info, mine are just ballpark numbers.
