Re: Farmall red paint peeling off
Posted by CNKS on April 19, 2007 at 19:24:47 from (204.249.178.32):
In Reply to: Farmall red paint peeling off posted by Dan130 on April 19, 2007 at 18:05:59:
I doubt if it is latex primer, latex doesn't last very long on metal. However, in a few years all automotive paint will be water based due to environmental regulations. Sand the red paint off, preferably the primer also, and use epoxy (2 part) primer. The epoxy is water proof. Most minor chips will only go down to the primer, and won't rust underneath. At a minimum paint with acrylic enamel. Since your trailer likely sits outside, acrylic enamel won't fade as much as the cheaper paints. You can also use Case-IH 2150 red, which is better than the farm store stuff.
