Re: pilot bearing replacement
Posted by BF8690 on April 20, 2007 at 08:47:30 from (138.163.0.38):
In Reply to: pilot bearing replacement posted by boochie on April 19, 2007 at 20:07:54:
Dude, I don't care about caps or your typing ability so here goes. The Pilot Bearing goes into the fly wheel which is bolted onto the crank. Find a socket the will easily fit into the hole for the pilot bearing and only contact the pilot bearing on the outer race. Then gently pound it in. I prefer to do that with the fly wheel off but that will make you have to split the tractor, so just be gentle while pounding it in.
