Re: H and 300 oil pump
Posted by Dave S. on April 23, 2007 at 02:54:40 from (65.167.221.30):
In Reply to: Re: H and 300 oil pump posted by jr300 on April 22, 2007 at 20:55:40:
Take out the cotter key that holds the oil pickup on and the 4 bolts for the cap. The cap will have pressure from the relief valve spring against it. Mine had wear from the gears running against it. I took it to the machine shop and they ran it over a surface grinder they use on cyl heads and never charged anything. Be sure to lube it up good with motor oil before putting it back together. Dave
