Farmall Tractors Discussion Board
Re: Re: Re: Re: Overhauling a Farmall H - How hard is it?
Posted by The Red. Amen on the oil changes. on May 03, 1999 at 07:14:25:
In Reply to: Re: Re: Re: Overhauling a Farmall H - How hard is it? posted by mj delaney on May 03, 1999 at 05:06:14:
I still have some sludge in this one so every 20 hours I will change the oil and filter until I get to 100 or so.
The rod journals looked excellent on mine also. I did not pull the crank nor the cam. She is settling down and running pretty darn good now. Just need a set of distributor springs and I am replacing the oil pump at hour 30 when I change oil and filter again. Still have some minor leaking around the oil pan and front timing gear cover.
Post a Followup
: Re: Re: Re: Re: Re: Overhauling a Farmall H - How hard is it?
