Re: Clutch for F12
Posted by Dave Allgire on April 23, 2007 at 19:07:13 from (71.85.239.227):
In Reply to: Clutch for F12 posted by Lyndel Butler on April 23, 2007 at 18:41:26:
First of all your clutch pedal free travel should not be more than 3/4". A couple of things to check. The distance between the three "fingers" to the throughout bearing should not be more than 5/16". This can be adjusted by rotating the adjustment nuts in the correct direction. There are three of them. They are held in place by the end of a spring. These springs prevent the nuts from rotating and getting out of adjustment. After the inspection cover is removed from the bottom of the the flywheel housing, you can reach in with a pair of pliers and rotate them. Of course, you would have to rotate the engine with the hand crank to reach all three of them. Next, I would look at the splines on the clutch shaft and the clutch plate. If they are excessivley worn, they can bind up. Next make sure the bearing release sleeve is lubricated. A thin layer of grease is all that is needed as there is no grease zert. Hope this helps.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
