Re: M Two Way Hydraulic Leak
Posted by AKB on April 23, 2007 at 19:29:57 from (71.220.99.27):
In Reply to: M Two Way Hydraulic Leak posted by NSC on April 23, 2007 at 19:18:45:
I just came in the house after finishing up a 2 way on an H and was going to post and seen your post,same problem,I put a tee on the filler tube plumbed the return in the side and vent out the top.switched them around same thing.I am thinking the vent stack has to be higher.any info greatly appreciated.
