Re: Checked out the 460!!!
Posted by Ksfarmmer on April 24, 2007 at 13:05:21 from (24.255.244.98):
In Reply to: Checked out the 460!!! posted by Butch WI on April 24, 2007 at 12:23:10:
Oh yeah, the 3 point adapters work OK, but they are definitely are real pain in the rear. Make sure you get the ones that angle upwards or you won't be able to lift your equipment very high. People are quite proud of these as well so don't expect these to be cheap either. Probably well over $100 for the pair.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
