Re: Rebuild IH 2444
Posted by Craig K on April 24, 2007 at 18:58:45 from (70.152.254.67):
In Reply to: Re: Rebuild IH 2444 posted by G Spence on April 24, 2007 at 14:50:49:
I have not priced the rebuild kits yet, so I can't say. I have had to order gaskets and other parts for the engine from Case IH. I have the engine running and hope to get some use out of it before a rebuild. My latest challenge has been to get all the leaks fixed on the hydraulics. I would suggest if you haven't already doing a search on the BD-154 engine on YT, I'm sure others have some great advice.
