Re: 3588 water in oil - where to start?
Posted by chadd on April 25, 2007 at 13:33:59 from (155.92.32.116):
In Reply to: Re: 3588 water in oil - where to start? posted by jmweb@alltel.net on April 25, 2007 at 12:58:51:
If the cavitation occurs far enough down the sleeve, the piston rings will be above the leak, and the leak will occur into the oil pan, and not the cylinder. You could drop the oil pan, pressurize the cooling system with compressed air and see where the leak is coming from.
