Re: 3588 water in oil - where to start?
Posted by Beck on April 25, 2007 at 14:19:40 from (199.150.177.135):
In Reply to: Re: 3588 water in oil - where to start? posted by jmweb@alltel.net on April 25, 2007 at 12:58:51:
You can get a radiator pressure testing kit from just about any auto parts store (some may even let you borrow one). Drop your oil pan and pump up the pressure in the radiator. You will see the coolant leaking. Usually only one or two cylinders will leak. If you want to be a real cheapskate, you could just buy a set of new O-rings and put them in. If the bearings look good you could continue to use the old ones. That MIGHT work.
I would never do a half*** job like that myself, since its almost as much work as doing a proper teardown and rebuild, but if you're real poor, you might get by that way. You'd probably have to do the work yourself, as most professional shops would refuse to do that kind of repair job.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
