Re: 3588 water in oil - where to start?
Posted by jmweb@alltel.net on April 26, 2007 at 07:23:49 from (71.255.44.179):
In Reply to: 3588 water in oil - where to start? posted by jmweb@alltel.net on April 25, 2007 at 12:08:14:
Thanks to all of you that replied - I've got a good place to start now.
I will pull the oil pan and pressurize the cooling system to see which pistons are leaking.
Not sure what my next step will be. I usually do not like to use Barr's leak unless it's an emergency - I may have time to pull the head and replace the sleeve or o-ring that is leaking. But - If one sleeve/o-ring is bad it seems like the others can't be far behind, so if I'm going to do the work to fix one I should probably fix them all. Is this a safe bet?
I don't want to run it with coolant getting into the oil, but I did want to ask - worse case will I damage the bearings if I run it this way?
Maybe the best bet is to try Barr's leak and use the tractor, then schedule it for a rebuild over the summer once the plowing is done.
Today's Featured Article - A Tinker’s Guide to Manifold Repairs - by Curtis Von Fange. A common characteristic of keeping older equipment is that some parts to make repairs can be extremely difficult to locate. For example, finding a replacement for a cracked intake or exhaust manifold on a unique tractor or odd brand can be a frustrating and downright impossible mission. So, what is an alternative solution to scraping out that ‘one of a kind’ piece of history? First, decide if you are one to try a repair yourself or have someone else do it. If you are uncomfortable about ... [Read Article]
