Re: IH 6788 trans grinding
Posted by K.B.-826 on April 26, 2007 at 18:57:22 from (24.180.143.209):
In Reply to: IH 6788 trans grinding posted by Harvesterguy on April 26, 2007 at 15:44:05:
I've never worked on one of those, but if I remember right, the transmission brake was hydraulic applied and controled by a electric solenoid. The brake itself is probably very similar if not identical to the one used in the 3088 series two wheel drives. I know that the parts on those are very expensive compared to the style used on the 06-86 series, but are much more reliable. Keep in mind that the range transmission is a collar shift and it is impossible to shift without grinding unless the tractor is at a dead stop, the engine is at low idle, and the clutch has been disengaged for at least three seconds. If it still grinds once these conditions have been met, then you go looking for a trans brake problem. On the popping out of gear problem, thats a classic case of failed detent parts underneath the range trans cover. If these 2+2's are anything like the two wheel drive 86 and 88 series, it wouln't be a walk in the park to repair. Cab floor and seat need to be removed, unhook shift linkages, drain a few gallons of oil and remove the cover from the left side of the range trans, block the park lock assembley in the unlocked (up) position, remove the range trans cover while a helper works through the removed cover on the left side and catches the reverse shift fork and makes sure it's woodruff key does not get lost.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
