Re: H gen voltage
Posted by Janicholson on April 30, 2007 at 06:21:11 from (199.17.6.122):
In Reply to: H gen voltage posted by henryviiii on April 30, 2007 at 06:15:24:
The voltage will be between 6.7 volts (if the battery is needing a charg) and 7.2 (if the battery is charged), and you are on H on the switch. The voltage floats some, and depends on the operator for adjustment with the H/L switch, and the third brush if needed (usually not) JimN
