806 oil light
Posted by jakob e. on May 01, 2007 at 07:46:38 from (134.129.45.128):
I have an 806 that has an oil light that will come on whe the tractor has warmed up. It is the one for the hydraulic system, because if I disconnect the sending unit for the engine the light will still come on. The light will only come on with the TA in the forward or direct drive position. If you pull the TA back the light will go off. The light is on regardless of were the clutch pedal is. The light will also go off if the brake pedals are pressed. The hytran level is O.K. Could the filter be plugged or is something out of adjustment?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
