Re: Basket Case Tear Down Part 3
Posted by El Toro on May 02, 2007 at 05:55:17 from (152.163.100.197):
In Reply to: Basket Case Tear Down Part 3 posted by neblinc on May 02, 2007 at 05:41:50:
I would use a piece of oak to tap on the connecting rods using a big hammer. Don't get too aggresive with the hammer and damage the block. The sleeve may come out with the piston
and you can use your torch to heat the sleeve and the piston can be removed.
Since the weather is warm, if that fails I would take that engine outside away from any building and pour some kerosene on top of the piston and set it on fire. You need that heat to free them.
I would only do one at a time too. Tap on the rod
with that oak as soon as the flame dies down. Hal
