Re: 706 diesel to gas
Posted by Nat 2 on May 02, 2007 at 07:04:05 from (64.80.108.53):
In Reply to: 706 diesel to gas posted by tim simon on May 01, 2007 at 21:50:52:
Yes, but you need more than just the engine to make it fit.
You need the front engine plate, rear engine plate, both side rails (they're longer on the gas version), radiator (outlet on the bottom is on the opposite side), and countless other piddly parts to make it "right." Otherwise, it's a cob-job.
Putting a gas engine in a diesel is a pretty dumb move, IMHO. The gas engine burns 2-3 times as much fuel, doesn't have nearly as much torque, and you'll be lucky to get 2500 hours out of a freshly rebuilt engine. Any junkyard gasser you put in that tractor will need rebuilding in short order.
Unless your diesel engine is damaged beyond repair AND you have a known-good gas engine to install, don't bother even trying. Rebuild the diesel.
