Re: Basket Case Tear Down Part 3
Posted by Tom Windsor on May 02, 2007 at 15:18:53 from (75.117.73.212):
In Reply to: Basket Case Tear Down Part 3 posted by neblinc on May 02, 2007 at 05:41:50:
You need to go ahead and get this engine off the tractor. and then, Turn it upside down. 1. Carefully get the front pulley off. That is a mouthful. (I broke mine getting it off) make sure you safeguard the key. I would put the nuts and bolts and pieces you are taking off in plastic bags and label them. You need to take this off with a puller. 2. Get the govenor, magneto drive, and idler gear off and put them up. 3. Then, CAREFULLY, remove the drive gear for the cam. ANOTHER MOUTH FULL. If you have never done this, you need good advice and a puller. I am not one to give advice on that subject cause I broke mine. and you are going to do that also if you pry on it and bang on it. This needs to come off with a puller. 4. Remove the big plate up front. 5. then, carefully and I say carefully, take the three pieces off at the oil seal in the rear. The little cross piece metal piece comes out first. Get it out, then take off the cast seal holders--two pieces bolted together. 6. Once you get the main bearing caps off, the crank will lift up just a little and then it can be rotated so that you can get to the nuts on the other rod caps that you cannot now reach. While you are monkeying around in the bottom, take out the oil pump...two bolts...and a little piece of pipe about 4 inches long...screw it out of the block because if not careful, you will break it off like everyone else does. The hardest thing here is removing the pulley off the crank and the cam drive gear. Some of the other guys on here will have to tell you how to safely do that. TW
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
