Re: '39 Farmall H - ignition
Posted by gene bender on May 02, 2007 at 17:31:48 from (67.55.226.214):
In Reply to: Re: '39 Farmall H - ignition posted by randy hall on May 02, 2007 at 12:32:03:
The early mags are the same as later ones the cable and slide sw will mount on any of the mags as they all have the holes drilled and tapped the cable sw was for the ones without a starter. if you need the cable sw i have one.
