Farmall Tractors Discussion Board
Re: 350 utility hydraulic fast hitch
Posted by Phil Auten on May 05, 1999 at 04:42:37:
In Reply to: 350 utility hydraulic fast hitch posted by Don H. on May 04, 1999 at 19:51:04:
Don,
Have you checked the fluid level? There also may be air in the rams. Try working them up/down without a load several times to push the air out.
If this doesen't help, check the O-rings on the rams, they may have gone bad on you.
Good luck,
Phil
Post a Followup
: Re: Re: 350 utility hydraulic fast hitch
