Farmall Tractors Discussion Board
Re: IH 300 utility - leaky axle, weight??
Posted by Phil Auten on May 05, 1999 at 04:48:30:
In Reply to: IH 300 utility - leaky axle, weight?? posted by ken on May 04, 1999 at 20:50:33:
Ken,
The 300 Utility weighs 3,400 lbs. by itself, per Guy Fay's book. I have no idea what the loader and backhoe would add to this, but I suspect you are beyond the 6,000 lb. mark. As for the leak, if it doesen't leak when full and level, leave it alone. If it worries you, go ahead and replace the seal, but be ready to do the other side as well, 'cause these things almost always need both sides done if one leaks.
Good luck,
Phil
Post a Followup
: Re: Re: IH 300 utility - leaky axle, weight??
