Re: H Voltage regulator
Posted by El Toro on May 03, 2007 at 17:05:29 from (152.163.100.197):
In Reply to: H Voltage regulator posted by BF8690 on May 03, 2007 at 15:37:48:
When you are getting 6.8 volts at the battery that isn't too bad. We would like to see around 7 to 7.25, but as long as the battery has enough charge to start your tractor I wouldn't worry about it. Do you have a high and low charging
switch? Some of these tractors had this feature where you could increase or decrease the charging rate. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
