H Voltage regulator
Posted by BF8690 on May 03, 2007 at 15:37:48 from (138.163.0.37):
What's the best way to check if your voltage regulator is working? I just re-wired my tractor exactly how it was when I got it. It looked like the wiring was original factor. When the engine is not running I have 6.2 VDC at the battery. When it is running I have 6.8 VDC at the battery. The ammeter is showing about 3 amps of charge running and 2 amps discharge not running. I can tell if the switch is working or not. Also, when I disconnect the the battery lead on from the VR I get constantly climbing amps before my meter shows infinity. I think it is working but I would like to know for sure. Any help would be great.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
