Re: Super H Idle
Posted by Bob M on May 03, 2007 at 18:02:55 from (69.205.124.61):
In Reply to: Super H Idle posted by GordoSD on May 03, 2007 at 17:38:05:
Gordo - A few possibilities: 1 (most likely) - When you stuck the carb back on you didn't get the tang at the carb end of the governor throttle shaft properly engaged in the mating slot on the carb throttle shaft. 2 - The governor to throttle tube is binding. Loosen both screws at both ends of the tube a couple turns. Wiggle the tube around then retighten the screws at the carb end. Then apply upward pressure with one hand to the front end of the tube while tightening the other two screws. 3 - Somehow the governor throttle shaft bellcrank got out of adjustment. The bellcrank is under the sloped cover at the top of the governor. Adjustment is relatively straightforward - post back if you need instructions. ---- If the tractor idled down OK before you rebuilt the carb, a weak spring inside the governor is not causing your problem. The gov spring is what OPENS the throttle - a weak spring will tend make the engine run slow.
Home
| Forums
Today's Featured Article -
Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
