Super H Idle
Posted by GordoSD on May 03, 2007 at 17:38:05 from (66.115.200.140):
This thing is driving me nuts. I've never encountered the problems I am seeing here.
Now it's the idle. I rebuilt the carb, with the complete kit. Runs strong, powers up no smoke, no leaks, but....it won't idle down to low idle. Double checked the idle stop screw, now have it way off, almost no friction. Can't get idle down by prying on the governor lever. Governor works as it should driving/pulling. Can this be a weak return spring? Does the spring in the governor pull the throttle closed or open it up?
How do I look see where the throttle plate is at low idle with the whole thing, governor and carb connected?
I'm tired of doing wheelies starting from the barn!
Gordo
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
