Re: H Voltage regulator
Posted by Bob M on May 03, 2007 at 18:53:27 from (69.205.124.61):
In Reply to: H Voltage regulator posted by BF8690 on May 03, 2007 at 15:37:48:
6.8 volts and 3 amps charging is probably insufficient to keep the battery charged. Like Hal says you should see 7.0 - 7.5 amps with the engine running at governed RPM. Also the ammeter should indicate about 15 amps of charge immediately after starting then taper off about 5 amps as the battery fills up. (This assumes you have a voltage regulator. If it instead has cutout and 4-position charge control switch the ammeter should show about 15 amps continuously with the switch set at "H" and the engine running at speed) ---- "Also, when I disconnect the the battery lead on from the VR I get constantly climbing amps before my meter shows infinity." Your last statement puzzles me a bit. Do you mean your VOLTMETER shows rising voltage when you pull the battery lead off?
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
