Re: Farmall 400 Locked up
Posted by Jossette on May 03, 2007 at 19:16:08 from (216.114.221.8):
In Reply to: Farmall 400 Locked up posted by TexasTedT on May 03, 2007 at 07:04:19:
see if you have a seasonal disconnect on the trans plate. It will be a 3" lever with a 9/16" bolt head with another hole to the side of it. If you do, take the bolt out and move the lever to the other hole and bolt it. This will take the PTO out and then see if the tractor will start. Then you will know if it in the back or the front of the drive...
