Re: H Voltage regulator
Posted by John T on May 03, 2007 at 19:27:51 from (66.244.83.147):
In Reply to: H Voltage regulator posted by BF8690 on May 03, 2007 at 15:37:48:
BF, Im not sure I follow whats happening??
2 amps of discharge not running???????
You mean when you shut the tractor off the ammeter registers - 2 amps. If the VR"s Cutout Relay was sticking closed I would suspect that to be wayyyyyyyyy higher (like maybe - 20 amps) so I question the ammeters accuracy for now. If you were to remove a batery cable would it still show - 2 amps or go to 0 ???????? If it goes to 0 there must be a minor short somewhere explaining the lower charge of only 3 amps and the 2 amp discharge.
You ask how to tell if the VR is working.... When running dead ground the gennys field post n see how many amps she charges then !!!!!! If that makes it charge at more like 10 amps right after a start up, I suspect a VR problem or maybe the VR isnt well grounded TRY A GOOD GROUND JUMPER WIRE TO THE VR"S CASE N SEE WHAT HAPPENS
I agree with Bob n Hal, 6.8 volts and 3 amps is too low right after a start up. Make sure the belt is good n tight and try a better ground on the VR (and genny also) and then try to dead ground the gennys field post n see how much she charges then. Also see if the ammetr stays at - 2 amps with no battery connection.
John T
