Re: Pinion Main Shaft bearing Removal....
Posted by Matthew(Mich) on May 04, 2007 at 09:08:48 from (67.177.148.199):
In Reply to: Re: Pinion Main Shaft bearing Removal.... posted by BF8690 on May 04, 2007 at 08:18:05:
Tractor is a Super H. The two models must be different because there is no place to get a long punch from the rear end area. Was thinking about heating the inner race that slide's over the pinion shaft a little. Any thoughts about using a little heat on the race?
