Re: Pinion Main Shaft bearing Removal....
Posted by kfox on May 04, 2007 at 12:02:33 from (63.18.185.143):
In Reply to: Pinion Main Shaft bearing Removal.... posted by Matthew (Mich) on May 04, 2007 at 07:20:33:
On a regular H, you remove the front shaft by pulling the front bearing retainer with the tapped holes in the retainer. Then you slide the pinion shaft & bearing forward and lift it out. The bearing is a slip fit in the bore. Be careful with the pilot bearing between the two shafts. If its bad, little pieces & parts will fall down in the transmission. ken
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
