mechanical ta replacement
Posted by jd jim a on May 04, 2007 at 22:00:48 from (24.180.143.209):
I'm doing my first mechanical TA, on a 686. Got a couple questions- I got a complete rebuilt unit with a gasket kit. The kit included four seals. One is very large and obviously fits in the housing between the TA clutch and the planetary. Two are the same size and go at each end of the top PTO shaft. The fourth one is small, same size as the one that goes in the planetary, between the input shaft and the carrier. Why the extra seal, or am I not seeing something? When I install the new TA clutch disk and pressure plate, will the pressure plate levers require adjustment, if so, how? There is a straight roller bearing on the top transmission shaft right behind the TA. I have heard it is a good idea to wrap a rubber band around that bearing to avoid knocking the rollers out when reinstalling the clutch housing to the TA housing- is this true? What happens to the rubber band, does it just slide back and stay between the bearing and the gear? Last question, I removed the hyd pumps so I could powerwash the clutch housing. The dealer says there are two different thickness gaskets to go between the hyd pump mounting flange and the clutch housing. Says this contols the backlash between the pump gear and PTO shaft gear. Says the thick one is most commonly used. How do I tell for sure? I have an I&T book but it is quite vauge.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
