Re: Super C cam
Posted by riverbend on May 05, 2007 at 05:59:27 from (208.160.33.43):
In Reply to: Super C cam posted by Dale in Ar. on May 04, 2007 at 20:11:39:
What do you get for lift on both cams ? If it is 0.010"-0.020" difference, it should not be a problem. These motors are low compression with a lot of room in the combustion chamber. If you test assemble the motor without a head gasket and turn it over by hand, you can tell if the valves are going to interfere with the pistons. You can check out coil binding at the same time.
Greg
