Farmall Tractors Discussion Board
Re: 1256 oil cooler leaks
Posted by Jim on May 05, 1999 at 15:58:45:
In Reply to: 1256 oil cooler leaks posted by karl fischer on May 05, 1999 at 13:41:38:
There are o-rings at the oil cooler and most times you can just replace them. But look for a grove in the elbow,if there is it will have to be replaced.You can just pull the line from the oil pump to the oil cooler.You will need 2 o-rings and a gasket. I would get them plus the hose from your Case IH dealer.
Post a Followup
: Re: Re: 1256 oil cooler leaks
