Re: Rear axle lube on Farmall C
Posted by georgeky on May 05, 2007 at 12:40:00 from (152.163.100.197):
In Reply to: Rear axle lube on Farmall C posted by 48C-MAN on May 05, 2007 at 12:32:52:
If there is no grease fitting on the ends of axles they have been broken off. They should be on the top side.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
