Re: Looking for painting advice
Posted by CNKS on May 05, 2007 at 18:52:11 from (204.249.178.32):
In Reply to: Looking for painting advice posted by Tom Windsor on May 05, 2007 at 18:37:12:
First of all, you do not need etch primer--because you are going to sand the sheet metal. Etch primer is for body shops using new sheet metal that they don't want to sand. For pits you need a two-part body filler type product-- there are many. You then sand it all off except what is left in the pits. If you sand too hard you will sand it out of the pits. Then use a two-part EPOXY primer, not etch. Cover that with a sandable surfacer or primer surfacer. Do not put the primer surfacer over the bare metal, it will not adhere nearly as well as epoxy. As you use the body filler on the pits, you can also use it to fill any small (1/8 in or less, I try to smooth it to 1/16 inch) depressions (dents). In the body filler used in the dents you may see some pinholes, those can be filled with glazing putty. The surfacer can be sanded, and reapplied until you are satisfied, but don't pile it on too thick. Some people recommend priming with epoxy before filling the pits. I don't know the advantage of that, as I prefer to put it on bare metal. Use 180 grit sandpaper before the epoxy. Do not sand the epoxy, but sand the surfacer with 400 grit before topcoating.
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
