Re: farmall h rim problem
Posted by GordoSD on May 06, 2007 at 05:55:47 from (66.115.200.140):
In Reply to: farmall h rim problem posted by vermontmat on May 05, 2007 at 15:47:57:
I just bought a drop center 11 inch rim for my Super H. It came off an M. I had to search high and wide for this rim. Seems no one makes that one, and they are pretty scarce. I paid 125 dollars, but the rim is near perfect, have never seen a better used one.
So if you all see a fence row Farmall with two good drop center rims figure it has 250 dollars worth of rear rims alons. I found dozens of bevel rims cheap!
I wouldn't trade that wider drop center for three bevel rims! SHop accordingly.
Gordo
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
