Re: All-fuel manifold?
Posted by gauger on May 06, 2007 at 06:21:11 from (4.252.144.105):
In Reply to: All-fuel manifold? posted by Mike CA on May 05, 2007 at 21:00:20:
It is definitely an all fuel manifold. It looks very clean but you will most likely find that the baffle is rusted in position pretty securely. If not and it is functional you've got an unusual one. There are lot's of those manifolds around for the H but most are in really bad shape. I've been lookling for a dual fuel manifold for my SH for three years with no luck.
