Re: Farm All Cub cuts out when hot / fuel line vac
Posted by El Toro on May 06, 2007 at 07:44:18 from (152.163.100.197):
In Reply to: Farm All Cub cuts out when hot / fuel line vacuum? posted by Mike Finger on May 06, 2007 at 07:25:21:
Some of those inline filters are not for gravity flow fuel systems like your Cub has. My garden tractor has an inline fuel filter, but they are designed for gravity flow. Your local auto parts store may have a filter or your local Case/IH dealer. I would remove that filter and let the strainer and sediment bowl do the filtering. Hal
