Farm All Cub cuts out when hot / fuel line vacuum?
Posted by Mike Finger on May 06, 2007 at 07:25:21 from (24.143.86.63):
After running for 15 minutes or so my '57 cub sputters and dies.
No fuel at carb, but when I disconnect line at filter and then
reconnect flow returns. Filter is new, carburetor. recently
serviced, but still a bit iffy as to the gasket seal (metal was
warped, screws had stripped the housing). Fuel line drops from
the sediment bowl and lays atop the transmission housing just
where the engine connects to the main body of the tractor. It
seems pretty hot in this area - could that be causing problems
in the fuel line?
Thanks for any thoughts you may have.
