CAN'T GET TRACTOR STARTED!!
Posted by QUINCY48442 on May 06, 2007 at 18:23:26 from (69.208.126.146):
i have an international 340 with a c135 gas engine. i was running it the other day when the engine just stopped running. it started running rough and dark smoke started coming out of the stack, then stopped running shortly after. it turns over and wants to start but doesn't. i took the distributer cap off and it does turn when i crank the engine, i have a clear fuel filter so i can see that it is getting gas (i also sprayed starting fluid in carb) when i crank it over it sputters and puts out a darker smoke. any suggestions would be great.
