Re: CAN'T GET TRACTOR STARTED!!
Posted by Janicholson on May 06, 2007 at 18:37:32 from (66.173.50.70):
In Reply to: CAN'T GET TRACTOR STARTED!! posted by QUINCY48442 on May 06, 2007 at 18:23:26:
Shut off the fuel at the tank. Let it sit for a day or two. Do not turn on the fuel, and try to start it with no fluid, or other stuff. If it starts, let it clear itself up, then open the fuel valve. If it gets smokie again, the carb needs to have the bowl taken off and the float checked, along with the needle and seat, I think it is flooding. The spark plugs may need to be cleaned before it will run (they are probably way carboned up. JimN
