C gas tank
Posted by Karl Hamson on May 06, 2007 at 19:04:34 from (139.142.96.209):
A day of dreary rain instead of the promised sunshine so I decided to tackle the fuel starvation problem on my C. I pulled the tank and as expected there is lots of rust and other crud. Any good ideas about getting this stuff out? I thoughtI might throw in a few pounds of clean pea gravel, put on some good rock and roll and shake it. The paint is pretty good so I don't want to send it in to get tanked.
I have read here about extending the inlet upward 1/2" or so which seems to be a good idea except you can never drain the tank should you ever want to. I thought I would stick a piece of 1/4" copper tube into the existing hole. Will this restrict fuel flow too much?
Also the gasket for the sediment bowl is bad. I have some 1/8" sheet neoprene will this stuff work or will the gas attack it?
Thanks, Karl
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
